Turn signal wiring help
I have a 2008 street bob with the rear turn signal relocation kit and the right turn signal stopped working so I took it apart. I found the the ground wire came out of the fitting for the light bulb socket, so I but a new wire on tested it and it worked fine. Next I soldered everything up and now it doesn't work right. The bulb will flash when I hit the turn signal button but won't stay lit like the other side. I'm just a little stumped and wondering if anyone has any ideas. Thanks
