Fairings info-Share yours
#271
Badhabit79 (06-01-2021)
#272
oh appologies... i responded to your message too btw.
I have the 14" cee baileys smoked windshield but JD sells them as well. JD also does have the entire fairing/hardware/windshield kit u can buy for around 650-ish. and if u go with another tsport fairing such as the Certified OKC Raptor like mine, u can just order JD's hardware kit and windshield.
#274
#275
Looking for a little advise when it comes to the angle of the fairing. I see it can be mounted with the top and bottom all the way back or one in and one out, I guess bringing the top out makes it more straight up and down. Can anyone tell me which way they find best?, does it make any difference?. My fairing is out to paint so when it goes back on I can try different things. Also got the wind deflectors to help buffetting and a 7 inch long ride shields recurve shield.
#278
#279
Thanks for the input. I have a set of Viking bags that I run on it for now. I will soon buy hard bags and have them painted to match. The bags I have now are the ones on my first post where the fairing is black. Bill, that is good advice, I plan to ride up to Charleston this weekend, I will take an allen with me. I am also going back to my two up seat, the saddleman solo in the painted pictures is a little hard on my old back.
#280
2015 wide glide with a lower rider s fairing. was pretty easy to install. had to drill a small hole in the lower triple and drill and tap 2 holes in the upper triple tree. also had to buy a headlight bucket, the WG headlight bucket is a little bigger and would not fit behind the fairing.
