rear signal removal
RE: rear signal removal
ORIGINAL: 98fxd
guys, can i get to the bolt for the rear signals with the rear wheel on?
seems tight in there. wondering those of you who have removed or relocated the rear signals did it?
Remove two of the rear shock bolts.
One on each side.
Lift the machine.
Won't be tight in there anymore, plenty of room.
Be careful.
mud
I did the rear tail light relocation thing and didn't put the bike on a jack or mess with the shocks or anything else. Like stated before just reach up in there with a wrench and loosen the bolt. It should just back off with your fingers after that.It might be a little tight getting that long winded bolt out of there, but it'll come out. The hole for the bolt is really pretty big, so there's a bunch of room to wiggle that bolt out of there. If you decide you have to loosen up the shocks make sure you loctite them.
ended up using ratchet wrenches to get the bolts loose and signals off. couldn't for the life of me get the bolts out without dropping the shocks. bought a crafstmen bike lift today, barely eeks under the frame. when the progressive 11" shocks come in, and it goes lower, im afraid ill have pissed waya 90 bucks...
thanks for the help gents.
tcsblues
05-05-2007 05:55 PM
