Vance and Hines disappointment
I have a 2 into 1 pro pipe. Love the looks and the sound, chromed holding up well etc. Problem is the dang mounting bracket snapped right where it holds the pipe. I've had the pipe foot two years but was hoping I could get some assistance from them. Called their support and was informed it was out of warranty,I knew this, and they wanted $120 for a new bracket. Sadly it appears no one but they carry the damn thing. I figured out a fix, using 1 1/4 inch square tubing and it will be fixed, just disappointed.
It looks as if the metal was just weak or not treated properly where it broke as it is clean break I have attached a pic.
Anyone think I'd be better off trying to weld it, although it looks kind of skimpy. I'm just worried if I make that section to strong it may send stress up the bracket.
The 90 degree bracket for my short shots cracked right up the middle. I just welded it back. A few months later I pulled the exhaust and realized the front head pipe was cracked at collar and the brackets holding the black heat shields to the pipes some where broken. Called vance and hines to find out they only have a one year warranty. They offered to sell me new pipes at a discounted price. After fighting them for about a week they went ahead and warrantied the pipes but I don't plan on buying vance and hines again.
A few years ago I had a support bracket break off my bub7 exhaust. They sent me a new one but I couldn't wait three weeks to get up and running. Besides that Their piece was made of 3/32" cheap white metal so what I did was I grabbed a piece of 3/16" cold steel flatbar, bent in a 90* L shape and drilled the appropriate hole for it to bolt up tho the main bracket which held the rear. The threads were damaged so I had to drill and tap a size up, and I used an old torca clamp to fix my new bracket to the pipe - and it never broke again.
Bam Bam!
Exhaust System Topics
07-12-2020 11:41 AM
Harley1016
2014-2023 Touring Models
17
09-18-2019 05:22 PM
