powder tubes between trees
I know ive been posting a lot recently. But im unemployeed right now and have all the time in the world to research and wrench on my bike.
Either way my question is if i powder coat my fork tubes sliders and triple trees will there be an issue getting the tubes back into the trees? Obviously i csnt coat the area under the trees for suspension travel. But whag about the area between the trees? Can i have that coated?
Also do the tubes and sliders need to be taken apart to powder them.i assume yes because the high temp will melt the washers. If i need to take them apart how do i do so?
Make
Make a set of tubes that fit over your fork tubes between the triple trees. Your measurement must be exact and there must be some sort of collapsible material to "Crush" because your trees are pushed together (top to bottom) as you tighten your headset bearings. I have seen some of these available for sale if you look.
You can powder the upper tubes and trees and maybe get some of those rubber dust covers to hide the lower part of the tubes to mask the fact they haven't been powdered.
You should def take them apart, but there is way too much info needed to write it all down here.
I wonder if you have a manual yet with all the things your doing to her, all the information and specs are in the book.
I just ran across a thread today (I've looked and can't find which one it was), somebody posted assembly/disassembly sheets from Moco on the forks.
I'm sure the thread is on the first or second page but I can't remember which thread it was. Pics and instructions.
Maybe somebody will know and post it.
Perhaps sleyedog is right though.
Because the last guy i talked to about dlc coating qouted me like 650 for the tubes.....any other thoughts?
