JD Customs T-Sport Fairing - Review
Old 04-01-2015, 11:37 AM
Jesse_81's Avatar
Jesse_81
Jesse_81 is offline
Few pics of the screen before at 15", what I cut off 1.5", the cleaned up edge and after at 13.5".
Attached Thumbnails JD Customs T-Sport Fairing -  Review-message_1426814857655.jpg   JD Customs T-Sport Fairing -  Review-message_1426910850692.jpg   JD Customs T-Sport Fairing -  Review-message_1426911902752.jpg   JD Customs T-Sport Fairing -  Review-message_1426911954595.jpg
Old 04-01-2015, 01:18 PM
robbyville's Avatar
robbyville
robbyville is offline
Nice! You're a brave man to cut it yourself
Old 04-01-2015, 01:34 PM
Jesse_81's Avatar
Jesse_81
Jesse_81 is offline
Being I mounted the second screen I had from J.D. I wasn't going to ask to return another one. Was going to have to Overnight a new one anyhow so cutting didn't seem like that big of a "risk" with the right tools.
Old 04-01-2015, 01:51 PM
stephenhelsel's Avatar
stephenhelsel
stephenhelsel is offline
Looks good! I have an 01 superglide, from what i read on site i would have to change my headlight from a top mount to bottom mount in order to use this fairing. Is that correct?
I want to get a fairing to help out on the longer rides and this looks the best I've seen.
Old 04-01-2015, 05:09 PM
Jesse_81's Avatar
Jesse_81
Jesse_81 is offline
Yes, it needs to be bottom mounted. They give you a new block and the bracketry ties everything together on the bottom from it.
Old 04-01-2015, 09:09 PM
stephenhelsel
Anyway u can get a pic on how its mounted from behind with it on? Just curious.. i really think this is gonna be my next investment but wanna figure out what all i need to buy so i can get a total cost...also how is your speedo mounted for clearence? I have a speedo and tac ontop of the light..do those need moves too?
Old 04-02-2015, 01:36 AM
Jesse_81's Avatar
Jesse_81
Jesse_81 is offline
I attached some pics. Cant really get my phone in there very good though. The top mounting bracket slides under your top tree and is bolted on with your riser bolts. Bottom bracket is held on by the headlight block bolt. The fairing itself has its on brackets and bolts on to those two top and bottom mounting brackets and tie everything together.
My speedo is on my console from the factory so that wasnt an issue for me. There is plenty of room to mount gauges in between the bars and the fairing tho if you wanted them in there. The last pic you can see kind of see the open space in there.
Old 04-02-2015, 06:46 AM
hell hound's Avatar
hell hound
hell hound is offline
it really does look good
Old 04-02-2015, 07:18 AM
stephenhelsel
Thanks alot.. those pics answered my questions... all i should need is a new headlight. Happen to know what size headlight u have off hand?
Old 04-02-2015, 09:29 AM
Jesse_81's Avatar
Jesse_81
Jesse_81 is offline
No problem. 5-3/4". It's a standard size. Very easy to find.
Quick Reply: JD Customs T-Sport Fairing - Review
