2014 fxdb rear fender swap questions
Hi guys i've done some research into this and wanna swap to the full fender think it will flow better with the LP bags soon to order. Im just confused on what years will work i think i saw like 06 and up will work any other years? and does anyone that know have better ideas then ebay ive found some but im not always 100% if they will work. also what else do i need for the swap any extra parts if i do this ill order the custom dynamics rear light turn/brake combo.
just trying to gather info if anyone knows thatll be great
I believe any 06 and up dyna fender will work. the following is a list I found online and used for my swap. I did not make the original list but i found it to work great. 59500255DH FENDER, rear (vivid black)
3022A SCREW 1 required (holds taillight base to fender) (HD dealer)
7964 NUT 1 required (clips onto tab on fender, 3022A screw goes through base into this)
68066-99A BASE ASSEMBLY (stock tail light base assembly for many models)
68026-99 SCREW (2 required) 8x32x1holds taillight to base.
68770-02B HARNESS ASSEMBLY (replaces stock wire harness. connects under seat, adhesive backing to stick it to the underside of the fender and runs to the tail light base)
If you are ditching your rear signals for the CD taillight you will need some new bolts and nuts for the rear of the fender and also something to plug the old rear signal wiring holes. I used some black plastic round plugs from the hardware store that work perfect.
Also I don't have the part# but if you get a brand new fender make sure you order the rubber seat pads (about 1" square)
yes I bought a new one because it was only $425 shipped new and people on eBay were trying to get $500 for used ones. Im sure you can find the part# for a denim black one as well, its just a standard lowrider fender 06-up
jackyl
10-01-2014 08:39 PM
