Which Gaskets?
Which Gaskets?
So I am going to swap out my OEM pipes for some Straight Shots here in the next few weeks. Pipes and baffles are ordered, but i'm not sure which gaskets to purchase. I looked at the HD OEM's and they appear to be not as thick as several of the aftermarket brands (including S&S) which I'd think would crush and seal when tightened down. I'm sure lots of folks have replaced pipes, what do you recommend?
Also, should I be using lock tight when installing the new pipes? If yes, blue or red?
Jay
Plymouth, MI
Jay
Plymouth, MI
They do work well as long as you get grade 8. Summit has a pack of ARP grade 8 cadmium for around $10 shipped. I started using the cometic copper gaskets with good results so far.
