entire motor filled with gas. how screwed am i?
Went out to go for ride and move the bike out into the driveway. Went to turn in over and gas shot out of the tailpipe...not a little either! Pulled the oil cap and its filled with gas. Can i just drain all the oil and refill or am i really screwed?!
The 1 time i didn't turn the fuel off....
Your probably fine. Just drain the oil and refill. Also remove your air cleaner and clean your intake and filter. When I bought my harley brand new (2014), gas seeped down into the oil from short start ups. So after leaving it caused the oil to spurt out of the intake all down the side of the bike. They explained it was from months of short start ups moving around the parking lot and that gas seeped down into the oil. Then when the bike reaches temperature it expands and was pushed out the breathers. Chances are your filter is saturated as was mine. They drained it, refilled it, replaced the air cleaner and everything was fine.
the gas in the engine will break down the oil... Cycle new oil in and run for a few minutes and then repeat the process. I'd go at least 3-4 times. You can get away with using cheap oil for this process, but go back to factory specs before running the engine at normal capacity
That's what I'd do anyway...
Junior
Junior
All these suggestions were good, except the petcock's not the problem. It's the float in the bottom of the carb. It's suppose to raise and close the fuel off. there must have been a small piece of crud in there. Drop the float bowl and clean it.
then start shutting the petcock off EVERY TIME you finish with a ride and are going to leave it for more than a few hours.
Don't ask how I know. Live and learn.
