entire motor filled with gas. how screwed am i?
Old 03-21-2015, 10:59 AM
stephenhelsel's Avatar
stephenhelsel
stephenhelsel is offline
Thanks guys again. I do realize that it is the float in the carb causing the problem. I was just saying if i would of shut the petcock never would of happened that bad.
Old 03-21-2015, 12:28 PM
stephenhelsel
Default it floaded again! wtf!
Ok......went to go ride today and the bike was floaded..when i went to start it a tone of gas shot out of the exhaust. Went to move it and it spilled out of air cleaner, opened dipstick and was filled with gas.
I drained the oil, opened bottom of carb to make sure float was good, put it back together filled with oil then started...would stay runnin..last about 30 sec. Opened oil plug and filled with oil again!!
I drained it again and have the carb completely off and cleaned it good.
Is there something else i should do or check before i put it all back together?
Thanks
Old 03-21-2015, 12:59 PM
Island Quest's Avatar
Island Quest
Island Quest is offline
Hi..It's got to be the Float is either Not seating properly and leaking or just plain Stuck..I can't think of anything else that would Fill up an engine with Gas Like that..I would also Check your Float height(the point at which the Float Shuts Off gas to the Bowl) the Specs should be in your Service Manual.
Old 03-21-2015, 02:44 PM
ss313's Avatar
ss313
ss313 is offline
Check your float and make sure that it doesn't have any liquid. If it does it's bad. Most likely just need to replace the float needle.
Old 03-21-2015, 02:59 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
Could it be the fuel valve/petcock is bad and is allowing extra fuel to flow into the engine?
Old 03-21-2015, 03:08 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,412 Likes on 5,012 Posts
No, it could not. Fuel level in the carburetor is controlled by the float and needle and seat.
Old 03-21-2015, 05:30 PM
stephenhelsel
Gonna look the carb over again before i put it back on tomorrow. 1 day off in 2 weeks.......just wanted to get a quick ride in..lol
Old 03-21-2015, 07:33 PM
NPoulos24's Avatar
NPoulos24
NPoulos24 is offline
Take carb and have rebuilt or replaced my 2 cents
Old 03-21-2015, 09:58 PM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is offline
x 2.
Now you have 4 cents of advice that says rebuild carb.
I don't know if kits come with new floats though. I would want to replace them though.
Old 03-21-2015, 10:38 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
All this and only two other people mentioned the needle and seat.
They can be bought as a set,, easy if your a wrench and do a little internet searching on your model carb.
While your tearing into it,, how's it running? Maybe "re-jet" while it's broke down?
Quick Reply: entire motor filled with gas. how screwed am i?
