Bike won't start error code below
Old 03-04-2015, 07:15 AM
robbyville's Avatar
robbyville
robbyville is offline
Default Bike won't start error code below
This morning I went to start my bike (in the absence of still being able to ride). Starter would not work (no cranking or anything no electric).
All other switches work, turn signals, trip meter switch, and the ignition switch that runs the fuel.
Since I recently changed my bars I oulled the wires to make sure nothing had come loose all good there.
I ran a diagnostic trouble code and came up with the image below. Can anyone tell me where this switch is and how to check for a short? Can it be reset or do I need a new fuse if that's what it is?
Old 03-04-2015, 07:18 AM
HardRider1's Avatar
HardRider1
HardRider1 is offline
That would be the kill switch on your handle bars, the ones you just changed. Best be going back over the wiring you have engine kill switch not working
96roadking's Avatar
96roadking
96roadking is offline
Is your stop switch turned off? It should be on your right hand controls on the bar, usually a red switch.
Old 03-04-2015, 07:24 AM
STRES's Avatar
STRES
STRES is offline
x3
thats what i was thinking buddy, good luck let us know how it works out
hopefully this was just a blonde moment!
Old 03-04-2015, 07:48 AM
robbyville's Avatar
robbyville
Well I don't have a red stop switch, but if you mean the off and run switch it seems to work. When I turn it to run, it makes a whirring sound as normal when the distributes the fuel. But when I hit the start switch nothing happens.
When I pulled the wiring out from the frame, I have two connectors. One of those connectors has multiple wires which appear to control tachometer, turn signals and the off and run switch. The single wire connector I assume runs the start switch. I checked all the wires and they appear to be fine. Although one of the red wires on the multiple connector seems a tad loose.
It all ran fine the day before yesterday, could there be a switch inside the switch housings that I missing?
Old 03-04-2015, 07:53 AM
STRES's Avatar
STRES
STRES is offline
battery voltage ok?
try un hooking the connectors and plugging them back and toggling the run stop switch
check battery connections
robbyville's Avatar
robbyville
OH MY GOD, worse then the worst blond moment, my bike wasn't in neutral!
I can't believe myself what a Putz!
Old 03-04-2015, 07:59 AM
STRES's Avatar
STRES
STRES is offline
Originally Posted by STRES
x3
hmmm i believe someone said that earlier....haha glad it was that easy
i blame this on PMS (parked motorcycle syndrome) it is a really aggressive disease
Old 03-04-2015, 09:16 AM
robbyville's Avatar
robbyville
I agree!
Even though wet and cold I needed to punish myself by going for a little ride to work and back. Had to turn around in the garage and navigate some ice on my driveway to get out to the road. Felt good to ride even if for only 20 minutes. Cranked the throttle to see the new torque feature on the FP3, if it's to be believed I got to 104 with WOT before having to slow down quickly, think I was in 3rd gear not sure. Then had to go home and change out of muddy pants wipe off the bike.
God I wish there was a way to delete the entire thread so that my stupidity wasn't forever immortalized.
Old 03-04-2015, 09:28 AM
Suede Blue Man's Avatar
Suede Blue Man
Suede Blue Man is offline
As long as nobody posts in here then it will finally get shuffled to the netherlands (not to be confused with The Netherlands) of threads, only to be brought up every three years by a new member asking a question about why his bike also won't start up as his first post.
It will die away.
Quick Reply: Bike won't start error code below
