Tire Replacement
Tire Replacement
Got my bike out last weekend and my rear tire was flat. Filled it up and the next day it was flat again. Found a 3/4" piece of steal in tire so have to replace it. My local dealer is booked up till May so will try to remove thewheel myself . Was wondering if there is anything I should watch out for when removing and reinstalling rear wheel. It's a 2005 Super Glide Custom. Any advice would be appreciated.
RE: Tire Replacement
ORIGINAL: Scott58
Be sure to put some anti seize on the axle when you reinstall.
Hopefuly the factory did when it was first installed.
mud
ORIGINAL: Scott58
Got my bike out last weekend and my rear tire was flat. Filled it up and the next day it was flat again. Found a 3/4" piece of steal in tire so have to replace it. My local dealer is booked up till May so will try to remove the wheel myself . Was wondering if there is anything I should watch out for when removing and reinstalling rear wheel. It's a 2005 Super Glide Custom. Any advice would be appreciated.
Thanks for the replies. Removed rear wheel on Sat. Only took me 5 min the Bolt came out easy. Removed belt guard and removed shock bolts loosened tightener bolts 3 turns eachand lifted bike with jack. This lowered rear wheel and I could slide the bolt out. Yes remembered to strap bike to Jack.Did the oppositeto install.
