CAN-bus and LEDs
CAN-bus and LEDs
Recently I installed rear H-D LED signals and a H-D LED tail lamp. Ever since, I have had rear LED blinking issues. I calibrated them with the BCM but they only work about half the time. I've listed my problem here before and been told I need a load equalizer for them, but my bike has a CAN-bus system and does not require load equalizers. When they stop working the console indicators begin flashing quickly and the rear LEDs stop flashing entirely. I have two error codes--b2151 and b2156 with pn 69994-128. All I've been able to tell is that the codes are for the rear signals. Sometimes the signals will function normally when I turn to the ignition switch, and then not work after engine ignition. Sometimes they will stop working mid-ride. Most of the time if I turn the bike off and on again, they will work again.
I have spoken to Harley about the signals several times and have not been given an answer. I am taking it in to the dealership in a few days if I can't resolve this myself. Has anyone had similar issues associated with their rear H-D LEDs or does anyone know a fix?
Have you checked the connections on the LED's? Sounds stupid, but a loose connection might cause your symptoms.
Sorted
Finally got this sorted out. I took it into Harley yesterday morning and had a return call 20 minutes later. They never really gave me an exact description of my error codes, other than to say the BCM was having issues communicating with my rear signals. They tried installing a rear load equalizer, but it caused even more signal dysfunction. Ultimately, they decided there is a compatibility issue with newer bikes and LEDs.
We decided to try tricking the BCM into functioning normally by installing stock incandescent lights on my forks. I've read about people doing this to correct signal problems. Today my girlfriend found several photos of LED/incandescent combos that are almost my exact setup. Two hours later my error codes were gone and all SIX signals worked perfectly. Parker, the Harley manager told me he "puts out the fires" and charged me absolutely nothing for their work (which included fork mount parts).
I had issues with these signals for months and did a good amount of research to try and solve the problem. Once again, the Harley dealership came through and my bike is at 100% again. Hopefully, this may be helpful for anyone else having LED problems.
Thanks for insight.
I've got a couple questions, which brand of LED's are you running? and what did the dealer exactly do to get rid of the error codes....did they install a IC light somewhere in the system?
I've got a '15 Bob, my Custom Dynamics LED turn-signals came in and will be installing them soon. Just wondering what to expect, looks like it's more than just cutting-out stock IC and splicing the new LED's in.
Thanks again.
Thanks again.
Thanks for insight.
Thanks again.
Thanks again.
I'm running H-D LEDs everywhere. Not sure if there will be the same issues with third party parts or not. The dealer removed the error codes by installing incandescent front turn signals on my forks.
Best of luck to you.
was the install process simple as cutting out the stock lights and splicing in the Custom Dynamic LED's?
thanks.
