risers
??? risers height.
What's your bike and are you using stock factory drag bars ? Tough question unless you find someone with your same set up. I guess you could always pull the four bolts in your risers and lift the bars. I put 10" apes with 2" risers on my 11 GW. I try not changing the throttle cables. They looked fine but the throttle would hang my at full lock either way. So I changed them as well. Oh and risers seem to be measured from top of tree to center of bar.
mfgarcia68
05-26-2009 12:01 PM
