Solid Risers
Old 02-09-2015 | 09:35 AM
SadistikCycles's Avatar
SadistikCycles
4th Gear
Default Solid Risers
Trying to find some solid risers for my '15 Dyna Fxdb but no such luck.. Everything I've came across is for 39mm front ends... If any one can shed some light on the topic it'd be greatly appreciated
Old 02-09-2015 | 12:56 PM
nevil's Avatar
nevil
Sorry if I'm misreading your question, but I'm not sure what you mean by solid risers. I've never seen hollow risers.
Since the risers bolt on the top triple tree it shouldn't make a difference what size the downtubes are.
Old 02-09-2015 | 02:49 PM
stupid_rope's Avatar
stupid_rope
...huh?
Old 02-09-2015 | 05:49 PM
acky1946's Avatar
acky1946
Do you mean solid riser "bushings"?? Remove the stock rubber bushings and install the solid ones so your high bars won't twist ?
I would think that many aftermarket vendors would carry them. And they're fairly inexpensive.
Old 02-10-2015 | 09:12 AM
blueangel73's Avatar
blueangel73
Mayeb he is talking about those solid risers that the Street Bob's had for a while. If so, I have the top tree on a shelf, even have the Loner Industries 1" riser for it.
Like these.
Old 02-10-2015 | 11:06 AM
Jesse_81's Avatar
Jesse_81
I'm not following. Risers, and diameter of your fork tubes have no bearing on each other...
Old 02-10-2015 | 11:11 AM
Jesse_81's Avatar
Jesse_81
Like these.
I'm very curious if this is the answer to the OP's question. Why these would be on a "to do" list would blow my mind. To each is own I suppose...
Old 02-14-2015 | 01:00 AM
SadistikCycles
4th Gear
Oh ha thought I put "bushings" in there, but yes that's the reason I want solid riser bushings because with high bars they just feel sloppy...sent an email to Speed Merchant so now just waiting to hear back
Old 02-18-2015 | 11:06 AM
stupid_rope
solid riser bushings are about 20 bucks on ebay. its just a chunk of polyurethane with a hole in the middle of it.
Old 02-18-2015 | 04:08 PM
BFMCdyna's Avatar
BFMCdyna
If a '15 FXDB is the same as a '14 FXDB you can probably use J&P Cycles P/N 5000796 for $10. This is a steel set that I used both on a 39mm FXR and a 49mm FXDC, you just flip the pieces upside down on the midglide. They take the flex out of the big bars and I didn't see any increased vibration or shaking. Some people use the $50 version and I've seen them sell for as much as $80. It's all in how much you want to spend.
2ndTink
10-03-2017 10:28 AM
Rollcage
06-03-2016 06:17 PM
Figstr
11-29-2011 05:25 PM
xdime00
04-08-2011 03:28 PM
Gary7
01-22-2009 01:42 PM
