05 Super Glide throttle/idle clutch Cable legnths?
looking at replacing all the cables throttle,idle,brake etc.with pretty stainless braided. shopping on ebay but want to make sure i get the correct sizes. Can anyone help with any info. If anyone where to get a good deal on these that would be appreciated.
RE: 05 Super Glide throttle/idle clutch Cable legnths?
i went with magnum sheilding. there not the cheapest nor the spendiest. there website lets you search per your model and year. it gives you the stock lengths as well as the inches over stock if you have to lengthen. i used this for my stock to 16" ape bar swap and had no probs with the lengths they provided. if you dont use them at least you can get the sizes!!! good luck there way better lookin than the stock black ones.
MIKEKIM
11-03-2011 01:44 PM
05, cable, cables, clutch, dyna, glide, harley, idle, replacement, replacing, replacment, stock, super, superglide, throttle
