FLT/FLH bags on my FLD
And for the bags adjusted one to level it out more. Prob got it as level as I could without having to heat up the bag or do any crazy stuff.
You should have shown us how they are hung on ...
I think you should make the effort to lower them, move them forward, and align them with the exhaust.
One of the reasons for the move them forward is that at some point I am afraid you will back into a high kerb or some street furniture etc and damage the hardbags.
It looks like you should be able to rig up a bagger support from the pillion peg mounting point to support them in the same was as the Street Glides have, without the need for a crash bar.
I like the idea and good luck with it. As I mostly ride on my own, and in non-hiway environments (read in traffic and round curves) I've thought of all the advantages of moving to the lighter bike as a touring platform and think it is a good choice.
OP,
Here is a side shot of my setup. My bike is lowered in the rear so the bags look to slant down in the back, but you can see they are in line with the exhaust, which would run parallel with the ground at stock height.
Crazy, I used to live in Morrisville, off of Davis Dr.
OP,
OP,
Picked up some Street Glide support brackets from eBay, cut the hole off that is use to hang it from the fender strut (to get raise it up about an inch and move it about an inch forward, this is personal preference). I drilled a hole in my strut and pressed in a threaded insert. Made a bracket that mounted to under the seat, kinda like what CV makes and made a bard to connect the seat bracket to the bag support (lots of trial and error to get alingment right. Then I bent a piece of flat stock to connect the rears together. I had to make my own mount oint for the front bag mount location.
The support bracket
The hole
The seat mount bracket
Mock up cross brace, change a little to fit under fender
This is the pocket on my saddle bag to fit around the shock during mock up.
The support bracket
The hole
How badly do this bag's you folks are using mess up passenger seating? They appear to look like your ol lady's legs be setting on the lids. I have a set of 2014 bags fender and all off a street glide i was thinking of doing this with. I dont have the lids though so i could mold me a set of lower profile lids i guess.
