handle bar switchs
It should be pretty evident by looking closely at the switch housings. There should be four screws on each switch housing. The two that are horizontal and roughly parallel to the ground are the 'clamp' screws and prevent the housing from rotating on the handlebars. The two screws that are vertical, one at the top and one at the bottom, keep the two halves of the housing screwed together.
Wookie47
Shovelhead
06-29-2014 08:24 PM
marvo75
04-19-2013 06:46 PM
