What did you do to your Dyna today?
Old 08-01-2017, 08:03 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Originally Posted by SixDD
I installed the front brake caliper and torqued the mounting bolts to spec, then installed a chrome insert just to dress it up a little.
Is that an ARP bolt kit I see?
  #7102
Old 08-01-2017, 08:22 PM
SixDD's Avatar
SixDD
SixDD is offline
Location: Depends on who wants to know.........and why.
Received 1,902 Likes on 1,109 Posts
I have no idea. Just some chrome bolts I ordered a while back. I forget.
Originally Posted by nodak2222
Joined the forum and ordered a bunch of parts
Ahaaa!
Welcome!
  #7103
Old 08-01-2017, 08:32 PM
Brsblls's Avatar
Brsblls
Brsblls is offline
Ordered the DK Customs Thunder Torque Inserts to see if I can take the edge off the sound of these Mean Mothers from Supertrapp.
  #7104
Old 08-01-2017, 08:52 PM
cvaria's Avatar
cvaria
cvaria is online now
Received 2,201 Likes on 1,687 Posts
Originally Posted by HrdNox
Tweaked the compression & rebound and added a quarter turn on the preload. Also threw in a pair of Phillips extreme silvers star bulbs or whatever their called. Brought the bars back about a half inch and put the brake pedal up one hole. What hole you ask?? Lol
whered this pedal/lever come from. i think i could use it to deal with the big *** filter issue. Nevermind, found it. Hammerhead.
  #7105
Old 08-01-2017, 09:20 PM
dklozik's Avatar
dklozik
dklozik is offline
Added my DK Customs 587 Intake and Breather system. Only bummer is they forgot to pack my catch can. So for temp, it has a hose running from under the intake.
  #7106
Old 08-01-2017, 10:01 PM
SixDD's Avatar
SixDD
SixDD is offline
Installed the front wheel and front fender.
Ordered a new lock washer for the big upper triple tree nut, ordered some chrome plastic hex bolt plugs for the triple tree pinch bolts. I hope I got the sizing right (I even broke out the digital caliper), and a set of chrome washer/beauty covers for the solid aluminum riser bushings.
Trying to think of something productive I can do to the bike today.
Man, I have the craving lately to go for a motorcycle ride bigtime. I know you guys know the feeling!
  #7107
Old 08-02-2017, 05:48 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,751 Likes on 3,962 Posts
After riding yesterday I dropped the primary fluid. Put the drain bolt back but left the derby cover off and put the Wide Glide on the J&S for the night.
Up early, as usual, this AM; took the bike off the lift and adjusted the clutch pack and clutch cable freeplay, refilled the primary with Spectro heavy duty primary chaincase oil, derby cover back on.
I've been using Mobil 1 10W-40 racing 4T in the primary and wanted to try the Spectro and compare it to the Mobil 1. With the warmer temperatures we've got right now the primary is a bit noisy in slow speed maneuvers; I wonder if the 4T is too light for higher temperatures. We shall see
SixDD, I did get your PM this morning about the Night Dragons. The Night Dragons are a more sport oriented tire with their composition and more rounded profile; a more rounded profile tire will be more sensitive to tire pressures. Too low of pressures will distort their profile more dramatically than would occur with a more squared off tire profile. That leads to handling issues and accelerated tire wear.
With more sport oriented rounded profile tires like Avon Cobras or Pirelli Night Dragons you should keep them at pressures that won't let their profiles distort, which means you'll run the pressures a bit higher than the typical squared off tire like a Scorcher.
On my Wide Glide with Night Dragons, the pressures I've found that work well on the 90/90-21 front are 39 - 41 PSI and on the 180/60-17 rear, 42 - 44 PSI.
Edited to add: F86 has found that similar tire pressures are working well with his Avon's...
SixDD (08-02-2017)
  #7108
Old 08-02-2017, 05:57 AM
Brsblls's Avatar
Brsblls
Brsblls is offline
Handlebars were crooked, like hands are turning right a little when the wheel is straight. Threads on the forum suggested this is improper tightening of the risers and clamp. Consulted the service manual, loosened and re-tightened in the prescribed order. It is a lot better, but not perfect. Will repeat this when a friend is in the garage and can hold the bars in place better.
  #7109
Old 08-02-2017, 06:01 AM
TinCupChalice
Replace the riser bushings while you're at it I prefer solid bushings but poly bushings are available inexpensively that will solve your issue. The rubber bushings degrade over time and distort, which may be why you couldn't get the bars perfectly aligned...
  #7110
Old 08-02-2017, 06:05 AM
Brsblls's Avatar
Brsblls
Brsblls is offline
Yes, thanks. Should have mentioned that in the post. I bought the Arlen Ness poly bushings with the recessed bolt heads. Used these in the install. Turns out the ones I replaced were the Harley Polyurethane riser bushings.
TinCupChalice (08-02-2017)
Quick Reply: What did you do to your Dyna today?
