What did you do to your Dyna today?
#6443
Sadly, nothing. I'm waiting as patiently as I can for my welder to arrive, then I need to dump my C25 and get it refilled with straight argon, run the power and aux ground and teach myself to TIG before I tackle the next step. Getting tired of waiting! Excited, tho.
Also ordered all my new consumables (alloy, electrodes, collets, gas lenses, cups, etc), 10/3 power cable, new Lincoln 4C style ADF cartridge for my helmet, diamond wheel to sharpen the Tungsten, etc.
#6445
Thanks! Good tip. I didn't know that. I figured steel would be OK.
#6446
Yep. Any brushes for prep too. When welding aluminum it has to be cleaned with tools just for aluminum or just for steel if welding steel. If you get contamination it will pop and sputter.
Aluminum takes practice. I max the machine out and once I see the puddle just start moving quick and don't keep heat in one spot to long or it will melt/warp, or pop a hole through it.
#6448
Tig is so much fun. Seeing some of the stuff going on your bike, I can't wait to see what you build. I get a tig and I'm making every bracket, battery tray, covers, out of aluminum for weight savings.
