What did you do to your Dyna today?
Old 06-04-2017, 12:54 PM
Nemosengineer's Avatar
Nemosengineer
Nemosengineer is offline
Bare Metal, I hope you prepared for your mirror search
"Ok, I'm Going in...wish me luck"
If you wan to get to the bottom of the pile you need this...
: Mike
  #6292
Old 06-04-2017, 11:39 PM
fxdlx's Avatar
fxdlx
fxdlx is offline
Rode the p!ss out of it. The winding coastal two lane highway here is fun.
  #6293
Old 06-05-2017, 02:05 PM
Jay Guild's Avatar
Jay Guild
Jay Guild is offline
Replaced the cheap skull badge on my electrical cover.
  #6294
Old 06-05-2017, 07:13 PM
bl_dg's Avatar
bl_dg
bl_dg is offline
Semper Fi! Now you gotta fix the horn and primary. Can't leave that EGA out there by itself.
  #6295
Old 06-05-2017, 08:39 PM
TBT3's Avatar
TBT3
TBT3 is offline
Originally Posted by TinCupChalice
Most don't seem to be reporting any issues with these knock off LED headlights. My knock off does set off the electrical diagnostic light if I switch it to low beam but it's not throwing any DTC's. Leave it on high beam, the CANbus is happy so I just keep it on 'can ya see me now' mode. I could add load to the low beam circuit so the bike sees at least 1.4a but I'd rather not cut in to the wiring so I just ignore the red diagnostic when I do need to use low beam.
It's a nice light and so much brighter than the stock headlight, that red diagnostic is my 'low beam' indicator I will look in to upgrading to a better LED but for now, the added lighting is worth that little annoyance...
Do you just leave your lights on High beam 100% of the time while riding?
  #6296
Old 06-06-2017, 07:49 AM
golferguy's Avatar
golferguy
golferguy is offline
Installed my 2" tank lift. Very Nice!!
  #6297
Old 06-06-2017, 08:55 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,751 Likes on 3,962 Posts
When I'm riding during daylight hours I just keep the high beam on. My bike isn't throwing any codes like your CANbus is, so it's just an annoyance that the electrical diagnostic light comes on when I do switch to low beam after dark. Once I restart the bike with the headlight switched back to high beam the diagnostic light clears and stays off until I go back to low beam again.
I don't like the fact it's doing what its doing but I do like how bright the LED is, I will address that with a different LED headlight; I only paid $50 shipped for this LED and it was a test to see if it was worth the coin for one of the better LED's; it is
::: snip :::
That's how a Wide Glide looks The 2" tank lift is the perfect choice, it follows the lines of the bike perfectly...
  #6298
Old 06-06-2017, 09:57 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,201 Likes on 1,687 Posts
the china 8690m knock off didnt throw any codes. But the 8690a is waiting for you when you are ready to have your mind blown
  #6299
Old 06-06-2017, 11:04 AM
SixDD's Avatar
SixDD
SixDD is offline
Location: Depends on who wants to know.........and why.
Received 1,902 Likes on 1,109 Posts
Today I started working on the new(used) OEM exhaust headers. I started cleaning up the front header with some 0000 steel wool and Blue Magic Metal Polish. I bought some semi gloss black high heat spray paint for the smaller black heat shields. I'm going to order some chrome heat shields later. I need the rear bracket and heat shield clamps then everything should be good to go - as far as the exhaust.
  #6300
Old 06-06-2017, 11:12 AM
wideglideCVO's Avatar
wideglideCVO
wideglideCVO is offline
Received 1,382 Likes on 808 Posts
Nice, looks great.
golferguy (06-06-2017)
Quick Reply: What did you do to your Dyna today?
