What did you do to your Dyna today?
#5962
Update: Added motor mounts, compensator, pri. chain, Dynatek adj ignition, Dyna coil. Think I found that extra 3 Hp.
#5963
Technically, nothing. But, I did start clearing out space in the garage. With a little luck and some Aleve (damn, this kinds of work makes me sore now ) I hope to start cutting and welding on the HF lift tomorrow night or Sunday.
#5967
WOOT... RSD Morris wheelset!!! After a call to Performance Machine, I found you can custom order most Harley compatible wheels in most Harley hub configurations, I explained in detail what I needed for a hub in a wheel that is not cataloged as a standard part number, a few minutes later special order part numbers were emailed to me. OUTSTANDING CUSTOMER SERVICE .
So what did I order...
18" X 3 1/2" Morris front wheel with a Dyna dual flange hub configuration, 25mm bearings. Special order P/N.
18" X 5 1/2" Morris rear wheel with a Dyna rear hub configuration, 25mm bearings. Standard P/N.
Tire sizes... (still shopping for price)
130-70 ZR 18 Front
180-55 ZR 18 Rear
You know the routine, Photos and review when everything shows up (6 week lead time).
: Mike
130-70 ZR 18 Front
180-55 ZR 18 Rear
: Mike
The following 2 users liked this post by Nemosengineer:
Ghost_13 (05-13-2017),
Tall Timber (05-15-2017)
#5969
If you want the luggage rack you need to call them to make a custom order. They were great to deal with and very responsive. The welding is top notch and the bar fit perfectly to my bike. With shipping it came out to about $350.
