What did you do to your Dyna today?
Old 05-08-2017, 04:59 AM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
Added the V&H Pro Pipe ( In Sig Pic ) which got a Great Price and That's it for a while, my funds are about gone if want to make this TN Road Trip coming up ..
  #5882
Old 05-08-2017, 05:06 AM
Proline1969's Avatar
Proline1969
Proline1969 is offline
Took her for our local bike blessing .
  #5883
Old 05-08-2017, 06:20 AM
rauchman's Avatar
rauchman
rauchman is offline
Received 3,946 Likes on 1,446 Posts
Installed Khrome Werks 12" Bobber bars on my Switch, along with throttle lines from a Street Bob. The holes for the lines weren't big enough to fit the connectors through. Had to get creative and drill/file out the hole to be larger on each side. Had Street Bob bars on, but idiot me dropped my bike in the driveway and bent the bar. Really like the pitch/angle of the KW Bobber. Had to use Street Bob risers (which came with the SB bars when I bought them) to use the existing brake line. Never did throttle work before. Everything is dialed in perfectly now.
  #5884
Old 05-08-2017, 09:09 AM
golferguy's Avatar
golferguy
golferguy is offline
Originally Posted by TinCupChalice
With the height of your apes I'd be running solid riser bushings. Always one of my first mods is to remove the rubber bushings and change to LA Choppers chrome solids. When you changed your bars to apes did you leave the rubber bushings in place or did you buy your Wide Glide with the apes already installed?
When you sit on the bike can you slightly rock the bars/risers back and forth? If you can you've got either rubber bushings or possibly poly bushings. If they're rubber you'll find solids will actually clear up those mirrors a bit and keep the bars solidly in position...
TC, how tight do you snug up the riser bolts? I put the poly bushings on with my 2" DK Customs extension. I did not torque but tightened very tight. It shakes so hard that parts of the bike were vibrating. I just took them off. I would like to put them back on if you or anyone else has guidance on snugging them down. thanks.
  #5885
Old 05-08-2017, 09:11 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
I know your question was directed specifically at TC, but the steel bushing inside the poly isolators takes the clamp load of the fasteners. Torque to factory specs.
golferguy (05-08-2017)
  #5886
Old 05-08-2017, 09:15 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,751 Likes on 3,962 Posts
HD calls for 30 - 40 ft-lbs on the riser bolts; mine are torqued to 40 ft-lbs. On my '13 I'm also using the DK 2" riser extensions but LA Choppers solid chrome bushings. Zero vibration issues, the mirrors are clear.
cggorman is as always, correct Torque to the factory specs...
Edited to add: I've never used poly riser bushings, I always use solids so I'm unsure if what you're experiencing is due improper torque on the riser bolts or if it's the nature of the poly bushings...
  #5887
Old 05-08-2017, 09:23 AM
Reindeer's Avatar
Reindeer
Reindeer is offline
I'm running poly bushings, vibrates pretty noticeably at idle, but smooth and solid when actually riding.
  #5888
Old 05-08-2017, 09:30 AM
golferguy's Avatar
golferguy
Thanks TC and cggorman. I will use the correct torque and see how they perform. Chrome bushings will be next if I am not happy!
  #5889
Old 05-08-2017, 09:41 AM
Mightyxxdan's Avatar
Mightyxxdan
Mightyxxdan is offline
Installed a rear brake light flasher. Saw something like this on a goldwing. I had a flashing tail light modulator LED on my old bike and they are expensive and involved a lot of wiring. I Wanted something cheaper and a lot brighter. Got an emergency LED strobe with integrated flasher. Its super bright and has 12 flash patterns. 2 wire hook up. Power to brake light and ground.
Amazon purchase
https://www.amazon.com/LAMPHUS-SolarBlast-Emergency-Firefighter-Sync-able/dp/B00CEKNCO0/ref=sr_1_17?ie=UTF8&qid=1494253560&sr=8-17&keywords=lamphus+led https://www.amazon.com/LAMPHUS-SolarBlast-Emergency-Firefighter-Sync-able/dp/B00CEKNCO0/ref=sr_1_17?ie=UTF8&qid=1494253560&sr=8-17&keywords=lamphus+led
Had to mount the light to a plate and mounted the light to my reflector. A little modification and ran the wires. Wasn't to hard of an install.
here is the finsihed install and video of the light.
esteboatan (05-08-2017)
  #5890
Old 05-08-2017, 10:03 AM
esteboatan's Avatar
esteboatan
esteboatan is offline
Excellent mate, I really want to get one of those on my bike for added rear visibility.
I just asked about doing something like this over in this thread
https://www.hdforums.com/forum/dyna-...-lightbar.html
Quick Reply: What did you do to your Dyna today?
