What did you do to your Dyna today?
Old 05-04-2017, 06:10 PM
SixDD's Avatar
SixDD
SixDD is offline
Location: Depends on who wants to know.........and why.
Received 1,902 Likes on 1,109 Posts
Today I packaged up the dash/console. It will be shipped tomorrow.
  #5812
Old 05-04-2017, 08:13 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,310 Likes on 1,859 Posts
OK, I just got done looking through some past P&A Catalogs 2007, 2010, 2012, 2014...NO Chrome FXDB dashes
  #5813
Old 05-04-2017, 08:49 PM
dirtdreamer50's Avatar
dirtdreamer50
dirtdreamer50 is offline
I did a google search for one, and they showed a bunch of links for chrome FXDB dashes. When I searched each site, there weren't any present. Seems companies have a way of grabbing search keywords and adding them to their search result description, whether they have it or not. Makes looking for something specific more difficult than it should be. None could be found on any site.
Chrome dashes are cool, but when the sun is in the exact wrong place, you can be blinded by the reflection, or so I have experienced. tp dd50
  #5814
Old 05-04-2017, 08:55 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Yup. The face of mine was textured, which helped some, but I still found it occasionally distracting. Honestly, though, gloss black and the glass gauge faces aren't much, if any, better.
  #5815
Old 05-04-2017, 08:56 PM
TBT3's Avatar
TBT3
TBT3 is offline
Have you guys seen any "short" dashes? Instead of the long dash that goes the whole length of the tank I'd like something that stops just below the ignition switch. I tried searching and I made post about it a couple weeks ago, but no luck. Any specific other model's dashes that would fit a Dyna?
  #5816
Old 05-04-2017, 09:03 PM
TBT3's Avatar
TBT3
TBT3 is offline
Originally Posted by TinCupChalice
I see you have the same kind of garage minions I do I've got 5, all special needs rescue cats; 4 of the 5 love my garage. The 5th is blind and because things are not in the same places all the time he sits in the doorway and listens to all the shenanigans instead.
You're turning in to a wrench; you've got the passion for it and every moment you're working on your ride you're learning more.
Nice work-around with the scissor lift; I see you realized you need to block up the left side of the frame so you won't put pressure on the pan when you support the bike; nicely done
We've got four of them, all rescues. Two of them were foster kittens my fiancé was just going to take care of until they were old enough to adopt. That was almost two years ago.
The new sissy bar is on! But I've still got to feed the signal light wires back through, get them hooked up and then tighten everything down. So not completely done but almost.
  #5817
Old 05-04-2017, 09:09 PM
dirtdreamer50
Check here. I found more different dashes on this site, than elsewhere else.
http://www.cas4.com/Instruments-Dash...s-Covers01.htm
  #5818
Old 05-04-2017, 09:15 PM
multihdrdr's Avatar
multihdrdr
Just off the top of my head (no research)...I think the short dash dynas use the larger speedo, but might be able to make a reducer ring, if the dash even fits the contour (I think some tanks are slightly different, again...haven't researched)
  #5819
Old 05-04-2017, 09:31 PM
TBT3's Avatar
TBT3
TBT3 is offline
Thank you. I see some on there like what I'm looking for, but they are either for another model or discontinued. I'll keep looking.
  #5820
Old 05-04-2017, 09:48 PM
bl_dg's Avatar
bl_dg
bl_dg is offline
Ordered some 2" bar stock to make some of those fancy 'gorman' style axle spacers. Also got in some material for a few other parts.
Quick Reply: What did you do to your Dyna today?
