What did you do to your Dyna today?
#5641
Bounced out to the garage first thing this AM; took the Wide Glide off the J&S and put a scrap piece of wood under her jiffy/extension. Removed the derby cover and the primary drain bolt to let the primary drain; then back in for breakfast; sirloin steak and eggs with 24 ounces of homebrewed Porter; I've heard that breakfast is the most important meal of the day, I need to start out right
Back out to the garage at noon; the primary is drained; adjusted the clutch pack and the clutch cable freeplay, 1 quart of Mobil 1 Racing 4T and buttoned her back up and took a nice ride. Back in to the garage and dropped the transmission fluid; the Redline was fresh last November when I put the bike down for her winter's nap but sleeping for that long, she needs new fluid. Used Mobil 1 75W-140 this time; I switch back and forth between Redline and Mobil 1 every other transmission fluid change but I swear, the Mobil 1 is the smoother transmission fluid. I think I'll stick with Mobil 1 in the transmission and quit with the Pepto-Bismol fluid, she's smoother with Mobil 1...
Last edited by TinCupChalice; 04-22-2017 at 05:52 PM. Reason: Just can't miss the chance for a typo...
#5642
She looks good with the longer legs.
TinCupChalice (04-23-2017)
#5643
Originally Posted by cggorman
Nothing, really. Made another trim washer and did some hardware polishing last night. My arms are sore so I'm resting today but I did get my needle thrust bearings in the mail so I greased them and put them on. Here's a couple pics. HUGE improvement! Can't beloeve I didn't do this long ago. Well worth the $6-ish each.
#5644
KG3 front turns
Need new mount nuts
ETA:They showed up
Need new mount nuts
ETA:They showed up
#5645
Finished up my brake upgrades. I added a P.M. rear 4 piston caliper, threw the DP pads it came with in the trash after the first test ride. I then got a set of Lyndal X pads, and now finally have good rear brakes.
I then decided to go ahead and add the P.M. 6 piston to the front, and put a set of Lyndal X pads before I tried the DP's it came with so it would match the rear. The fronts were good before, but are great now.
#5646
Froze my *** off..., and pissed on a bit by mother nature..., also verified the sissy bar will delivered in 3 wks
All things considered - it was an absolutely wonderful day..., on the sled
Ghost
Ghost
#5647
Sorry, they're bearing pullers and presses for hubs, stem, and neck. They ship with flat washers and kinda suck in the feels department.
#5649
Location: Depends on who wants to know.........and why.
Received 1,902 Likes
Went to the dealer and ordered a black battery cover band I wanted(off a 2017 low rider s)
They had a veterans expo going on. Old codgers and Harley-Davidsons everywhere!
#5650
Thanks! I'm really liking the look and feel of the bike; I did some slow speed parking lot exercises yesterday and I'm starting to get a real feel for how the longer tubes changed slow speed control.
Love the P.M. calipers on your Wide Glide Those are a great upgrade...
