What did you do to your Dyna today?
Old 04-03-2017, 08:47 AM
Jay Guild's Avatar
Jay Guild
Jay Guild is offline
Originally Posted by NORTY FLATZ
Wouldn't a shorter shift arm = a longer shifter throw?
With all other things being equal yes. It also requires more pressure. My opinion is the shorter shift arm is meant for peg foot controls where the shifter lever is shorter so that actual throw distance is the same as the longer shifter arm with a longer shifter lever on the foot board kits.
  #5392
Old 04-03-2017, 10:37 AM
blueangel73's Avatar
blueangel73
blueangel73 is offline
When I went from mids to forwards, it came with a taller lever much like the one in the pic, only it curved forward rather then aft. When I went to footboards, the taller one in the pic is the one that came with that kit. So either with the Forwards or the Footboards, you get the taller lever, the just curve in different directions. The shorter lever was originally from a softail with heel/toe option. So changing the spline that the heel/toe mounts to is really the only change I made from the footboard lever, the rear trans lever is the same and the shift rods is a neutral subject, don't believe its length effects much when shifting.
  #5393
Old 04-03-2017, 10:40 AM
BMCsteve's Avatar
BMCsteve
BMCsteve is offline
Wife in the garage helping put on the new exhaust and intake this weekend
  #5394
Old 04-03-2017, 12:05 PM
Whtwolf14's Avatar
Whtwolf14
Whtwolf14 is offline
Decided to keep her for another season or so..."life" just gets involved, ya know? I was going to make the jump back over to the Softie side, but it's just not a viable option at this point. So...on the bright side, the wife is giving me free reign to make it more mine...er "ours", yeah that's it...
  #5395
Old 04-03-2017, 05:40 PM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,751 Likes on 3,962 Posts
A bit of a rethink this afternoon. I have another little project I'm working on with the Wide Glide right now but I can't quit looking at the plumbing for the Jagg low mount oil cooler and the 3Guyz oil filter relocation. I just replaced all the hoses for both when I installed the Predator front mount, but now I don't like it. I don't like those hose angles and curves; something's going to give eventually with the combination I've got; the low mount oil cooler, the oil filter relocation, the +3" extended shift rod, they all determine those hose bends; and it's only her life blood flowing through them
Time for a change. Broke out the razor and cut off all those new Gates 400 PSI reinforced hoses and removed the Jagg thermostatic adapter. Silly thing is 1 1/2" thick and eats up precious room and I can't see the point to it with a second adapter sitting on top of it.
I'm going to plumb the Jagg and the oil filter relocation in series without the thermostatic adapter. Out from the 45° of the billet engine adapter, in to the low fitting of the Jagg, out to the in of the oil filter mount, back in at the center fitting of the billet adapter.
I'll be curious if engine temperatures change removing the thermostatic adapter; I'll monitor the temperatures if it ever quits raining and sleeting
  #5396
Old 04-03-2017, 06:15 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
My prediction...Temps might change on cool days and it will take a bit longer to warm up, but you won't see a difference during typical operation...unless it restricts flow when open...which it shouldn't if properly designed. Good test! I've thought about taking mine out but I do ride in the cold. Hmm...I wonder what the end is for acceptable oil temps...
Once you get back to Florida, you'll probably be happier without it.
Interesting note, my Jagg low mount has long hoses that run under the crankcase back to the tranny. The thermostat is under there as well.
  #5397
Old 04-03-2017, 06:20 PM
TinCupChalice
Yea sort of what I figured as well. Warm up on cooler days will be a bit slower but my observed temperatures wouldn't change overall. That adapter eats up so much space with the Posi-Lock fittings on the relocation creating hose bends that just don't inspire confidence; when my gut says that bike is in a no ride condition I trust it.
Still trying to figure out how my front forks fell off tho...
  #5398
Old 04-03-2017, 07:03 PM
ludville1's Avatar
ludville1
ludville1 is offline
Installed a K+N air filter. Did some research/thinking on a Vance+Hines Upsweep exhaust and FP3 tuner for the bike. Tin Cup was right, LOL!
  #5399
Old 04-03-2017, 07:43 PM
Fxdh2112's Avatar
Fxdh2112
Fxdh2112 is offline
5th Gear
Got the rest of my parts in for the inverted front end swap, modified xr1200 setup.
  #5400
Old 04-03-2017, 08:36 PM
dirtdreamer50's Avatar
dirtdreamer50
dirtdreamer50 is offline
Make sure pics are posted. Currently own an XR, and would like to see how it looks on something other than the new Roadster... tp
Quick Reply: What did you do to your Dyna today?
