What did you do to your Dyna today?
Old 10-27-2023 | 07:10 AM
NEWROADSTER's Avatar
NEWROADSTER
Originally Posted by brownie4412
Its a 117 @ 11.2-1, t-man street performer cvo heads, 58mm tb, 6.3 inj, Thrashin AR exhaust and Cycle-Rama 630 cams.
It runs amazing, which is all I care about. It’s just different from the way it was previously setup with the tman 590s and the 30t compensator. That build was hitting 120 tq @ 2500 rpm. It would rip your arms off if you let it, but it also petered off fairly quickly and felt labored on the interstate during long rides. Don’t even get me started about riding it in the rain lol
This setup was geared more towards highway riding and being less picky on fuel as I plan to keep going out west. I can grab 4th or 5th on the interstate and be north of 120mph in the blink of an eye. I’d say mission accomplished.
By the way, I looked up your tuner, It looks like he is a bad *** in his own right! Congratulations on a great package!
The following 2 users liked this post by NEWROADSTER:
brownie4412 (10-27-2023), Dynawobble (10-27-2023)
  #16912
Old 10-27-2023 | 09:28 AM
the_huber_show's Avatar
the_huber_show
checked my tire last night and it dropped about 5psi. Hoping that is it and it's the same tonight (fingers crossed)
  #16913
Old 10-27-2023 | 11:01 AM
John CC's Avatar
John CC
5 psi would equate to a temperature change of about 50 degrees F.
Did anyone put the wheel into a water tank? Pump it up to the max allowed pressure and stick it in a tank and watch for bubbles. Eventually it'll show itself.
  #16914
Old 10-27-2023 | 11:15 AM
the_huber_show
Temps have been consistent this week at about low 50's overnight and anywhere from 70s-80s during the day. No water tank. Sprayed around the valve stem and both sides of the wheel along bead
  #16915
Old 10-27-2023 | 11:51 AM
John CC's Avatar
John CC
Isn't this the tire that came from Cycle Gear, and was also checked by your son? Neither of them have a tank? Some times that's what it takes. A little dish soap in the water makes it bubble up a lot better.
It's possible the tire leaks through the tread or sidewall. Spraying the bead won't expose that.
  #16916
Old 10-27-2023 | 11:53 AM
the_huber_show
Yes it was purchased from Cycle Gear. My buddy checked it with spray and balancer to make sure it was balanced. I've never heard of the tank so I am not sure if they have one or not. First time I've had an issue like this with a tire.
  #16917
Old 10-27-2023 | 01:53 PM
98hotrodfatboy's Avatar
98hotrodfatboy
@brownie4412
Yeah I have to agree with you, mid-thirties would have been my expectation at the minimum... Not really sure about the heads but that's usually where everything's done.. I personally like Hillside's heads.. There's a lot of knowledge in that shop when it comes to the art of air flow....
I didn't study your build but usually early cylinder fill is the key to low down torque and power... With that in mind you would probably not see that dip.. This is one of the reasons why I like Woods cams.. They fill the cylinder early making for good power down low while still running out up top...
  #16918
Old 10-27-2023 | 05:02 PM
John CC's Avatar
John CC
https://www.tooldiscounter.com/produ...-test-lis19822
The following 2 users liked this post by John CC:
98hotrodfatboy (10-28-2023), the_huber_show (10-30-2023)
  #16919
Old 10-29-2023 | 02:06 PM
snake_eyes's Avatar
snake_eyes
Put it on the lift for the next 6 months till it gets warm again.
The following 3 users liked this post by snake_eyes:
Dynawobble (10-29-2023), Garage Queen Rescue (10-29-2023), the_huber_show (10-30-2023)
  #16920
Old 10-29-2023 | 02:09 PM
Dynawobble's Avatar
Dynawobble
The pain in my heart is immeasurable!
The following 3 users liked this post by Dynawobble:
snake_eyes (10-29-2023), the_huber_show (10-30-2023), Tom H (10-29-2023)
