What did you do to your Dyna today?
Had an annoying primary gasket leak after replacing the primary cover. Reseated the same gasket and made sure the mating surfaces were as clean as possible, seems to be holding for now.
https://shop.advanceautoparts.com/we...0051&langId=-1
If you ever reuse gaskets you should at least copper coat them permatex makes it..
Drop the mike.
I finally had time to do a little riding this weekend. I rode over to Jefferson Texas and stopped in at the local beer joint to have a cold one. I met a nice couple there when I was leaving. The gentleman was retired and had owned every kind of bike from Harleys, BMW,s to Gold Wings. The wife insisted on a picture.
The following 5 users liked this post by NEWROADSTER:
98hotrodfatboy (10-23-2023),
benscratchin (10-25-2023),
Dynawobble (10-23-2023),
Garage Queen Rescue (10-23-2023),
snake_eyes (10-23-2023)
Took my wheel back off as Cycle Gear either didn't get the bead to set on my tire or valve stem isn't set right as I rode 600 miles and it's flat. Filled it up to 40psi and with in a day it was flat again.
That's a **** sandwich! I didn't even know they did tires. I just buy helmets from them now and again.
I should have known better when the guy was like if you go chill in your car, I can knock this out really quick for you (as I was killing time waiting by just browsing the store)
They do. You have to remove your wheel from the bike and if you buy the tire from them, it's $25 for mount/balance. If you buy the tire somewhere else, it's $50.
the_huber_show (10-23-2023)
