What did you do to your Dyna today?
Old 07-15-2023, 05:59 PM
Jack Schitt's Avatar
Jack Schitt
Jack Schitt is offline
Default Replaced my speedometer and brake caliper.
Finally found a used replacement and installed it. Tested fine and had 26 K miles on odometer so mine was at 14 K so all I can do is make a note in my service manual.
Also replaced the left front brake caliper due to a constant drip. Saved the old one for pads are still good and can rebuild it if needed. Or if someone else needs one to rebuild.
Just happy everything is working again.
Added a USB dual port with voltmeter mounted on bars and spliced (soldered) into the low beam yellow wire to be able to keep my phone charged when using maps.
Will do complete oil change soon.
  #16612
Old 07-15-2023, 07:25 PM
rocket23's Avatar
rocket23
rocket23 is offline
Received 3,615 Likes on 2,870 Posts
2 hour cardo trip I’m gonna like 1 up riding.
  #16613
Old 07-15-2023, 07:50 PM
Volkspanzer's Avatar
Volkspanzer
Volkspanzer is offline
Originally Posted by Tom H
Good point on the clutch cable. Will also check for any wires and evap hoses that may be in the way.
I didn't know that they used a U clamp, I figured they bolted to the forward control/foot peg bolts.
Thanks again,
Tom
they usually do mount to the forward control mount but with the holes already occupied the u-clamps have to be used. That’s what I’m going to have to do since I went from mids to forwards.
  #16614
Old 07-17-2023, 07:48 AM
the_huber_show's Avatar
the_huber_show
the_huber_show is offline
Bought new rotor and pads as Saturday my rear brakes decided to stop working. When I stopped to look at them the rotor is screwed and the pads are stuck out. So I will be fixing that here soon
  #16615
Old 07-17-2023, 08:28 AM
rocket23's Avatar
rocket23
rocket23 is offline
How many miles??
  #16616
Old 07-17-2023, 08:33 AM
the_huber_show
Originally Posted by rocket23
How many miles??
I think I'm at around 26xxx-28xxx somewhere in that ballpark and they are factory. When the caliper got stuck it grinded the pad all the way down and then grinded into the caliper
  #16617
Old 07-17-2023, 09:22 AM
rocket23's Avatar
rocket23
rocket23 is offline
Yikes.
the_huber_show (07-17-2023)
  #16618
Old 07-17-2023, 10:05 AM
the_huber_show
Ya I'm sure it's gonna ride so much better after the update
  #16619
Old 07-18-2023, 02:51 AM
Von Gruff's Avatar
Von Gruff
Von Gruff is offline
Had a look at the new paint today but the clears are not added to give it depth and life. I have seen and love the paint in how it will finish but was very pleased with the decals I had done and were added over silver base coat and peeled off after top coats were applied. The blue is much darker and deeper than it shows here as the winter light was not good to show true colour but will get that shown after it is all back together and I can get it in the right light. Have a set of 3 degree stearing head bearing cups and 3 inch over slugs on the way to add a little extra up front.
The following 6 users liked this post by Von Gruff:
Garage Queen Rescue (07-18-2023), Narddog (07-19-2023), rocket23 (07-18-2023), snake_eyes (07-18-2023), StanC (07-18-2023), the_huber_show (07-19-2023) and 1 others liked this post. (Show less...)
  #16620
Old 07-18-2023, 02:24 PM
Jay Guild's Avatar
Jay Guild
Jay Guild is offline
Still the chopper blue then?
Quick Reply: What did you do to your Dyna today?
