What did you do to your Dyna today?
Old 04-11-2019 | 07:52 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by vrt93
Not so much today but the last couple of weeks. Made a front crash bar, front stabilizer, and handle bars and added a front fairing as well as some 11" Progressive 412s
I'm a Sucker for "Made" parts ... most of the time
Keep it up
  #12152
Old 04-11-2019 | 07:53 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by Reindeer
Teaser pic of my tank. Metallic is sprayed, will get clear coated, then pinstriped/decals, and more clear.
Mid-April I'd love to be riding, but it's blizzarding here in Minnesota (8" so far, more on the way) so I have a little time.
Well ... how are you feeling about it so far ... Stoked?
  #12153
Old 04-11-2019 | 08:40 PM
REW13's Avatar
REW13
Natedog, Multi is right. Your rim will be a little off center but your ride will be true. It looks worse when you put an over size wheel on it too...
It's when you crab walk you have an issue
natedog_37 (04-12-2019)
  #12154
Old 04-11-2019 | 09:46 PM
SluggoMagoo's Avatar
SluggoMagoo
Added the saddlemen highwayman blue flame tattoo saddlebags yesterday. Once I figured out how to mount them, it only took an hour.
  #12155
Old 04-11-2019 | 09:59 PM
multihdrdr's Avatar
multihdrdr
If those "throwovers" are touching your fender, you may want provide some paint protection before it's too late
  #12156
Old 04-12-2019 | 12:24 AM
Reindeer's Avatar
Reindeer
The blizzard or the tank??
I'm happy with the tank so far, but the best part is still coming.
The blizzard didn't turn out quite as bad as predicted. Still would prefer the high 60s we had a couple days ago though.
  #12157
Old 04-12-2019 | 04:14 AM
SluggoMagoo
What do you recommend? The yoke across the fender was actually a temp solution but, I also put plastic push pins (like those in automotive store self help) up through the holes keeping the actual material off of the paint but, still the plastic is against the paint in 4 small locations. The sides of the yoke is bolted to the fender frame support and the bags reset against a bracket that I purchased last year. The bottom of the bag has a quick release strap tie-down which ties to that bracket. This morning I decided to remove the across the fender idea and I stuffed that material where the bracket goes and cable tie it. There seems to be plenty of support and nothing is touching any moving parts. Now everyone can see my fender decals again. Thanks for the heads up.
  #12158
Old 04-12-2019 | 09:21 AM
toddskill's Avatar
toddskill
Originally Posted by Bob_fxdb
Nice picture
This was after I put the shocks on so that's what I was looking at when I took it. I ain't no photographer.
  #12159
Old 04-12-2019 | 10:57 AM
Jay Guild's Avatar
Jay Guild
Looked for the source of a rattle around the engine nervous that I didn't tighten a bolt in the rocker box and it sounded like more than lifter noise. Relieved to notice the shifter levers were not tightened down enough to prevent the lever from loosening off the shaft so the arm was rattling against the mount.
  #12160
Old 04-12-2019 | 11:23 AM
Alpha_06's Avatar
Alpha_06
Default Want riser and bar
My next item is riser and bar with a speedometer cluster - looking at Big Bear Performance in California. Also, considering changing my detachable windshield to a permanent fairing.
Quick Reply: What did you do to your Dyna today?
