What did you do to your Dyna today?
Got the Lowbrow Customs chopped front fender.
Attachment 596017
Attachment 596018
Attachment 596019
Figured I'd post a mock up photo, as I couldn't find a picture of one mounted on a bike before I bought mine.
Attachment 596017
Attachment 596018
Attachment 596019
rossWG (10-30-2018)
Heard a clicking sound from the rear wheel and a bolt on the rear pulley had busted off in the hub. Took off the rear wheel to get the stub out and discovered a second bolt was also broken off in the hub.
Originally Posted by CryingJoker
I like that more than I would think. I'm curious to see the full look.
Got a couple other things planned, I'll post pictures in the spring when it's all back together.
SixDD (10-28-2018)
Did you get any pics of that?
Well got mine all together again this evening finally. Seemed like every little thing fought me. Got the bike off the lift and wiped down. Went to test ride it and two little problems arose. 1st one was one of the floating rotors wouldnt settle and had a bad rattle. Went to look and realized I didnt put the spring washers on the new bolts for that side duh me. The other problem was battery light came on. Pulled in and hooked up the charger showed right at 12 volts. Cranked back up and it dropped didnt go up. I put it on charge and said thats enough for tonight I'll just cause more problems than I fix. Now as I sit here I think I bet the regulator got unplugged while I had it strapped down knowing my luck. Always something you overlook. But did snap a little pic to show I am impressed the wheels look better than I was worried. Hopefully tomorrow after work I can find/fix the little errors while it's perfect riding weather.
Nope, but the other three bolts were also backing out. It could have been ugly.
