What did you do to your Dyna today?
Installed 180/60B17 Scorcher and Laylo plate holder.
https://www.hdforums.com/forum/dyna-...low-rider.html
During the project I noticed that my rear brake pads are getting thin. That’s a job for tomorrow.
I use a ColorRite vivid black touch up pen; it won't come off unless you want it to. I knew she felt off. Next corner I turned off to check her. A Dyna has certain vibes, and when it's wrong you need to find out why!
Missed still owning it and trying to figure a way to buy it back as it's still sitting stripped naked on the dealer floor. Love love love my RG but having a lighter bike sometimes is nice also. Still have a Vulcan 750 but don't trust it and it has no soul.
Yes checked flanges and all good.
checked all wiring for continuity on the weekend. Can’t find any faults in wiring.
When I watch the data logs I can see the rpm at idle spike up to 1200-1300rpm (after 2-3hr ride, when get P0505)
Previously when I had manifold air leak it would high idle all the time, cold or hot, short or long ride.
cheers
cheers
SixDD (08-20-2018)
I know some of the early EFI bikes had a TSB recommending a change to the injectors. I think they went to a wider spray pattern. Not sure what the symptoms were that drove that change. Possibly erratic idle? As the engine warms, fuel atomization improves, which may cause a higher idle in engines with less ideal spray patterns. Just speculating...
Forgive me if I dont know what the hell I'm talking about.
Next up: check for intake leaks.
All good questions. I agree that it seems unlikely if the bike used to run fine. I can't answer the other questions, but I'm sure we have members that have done this who would know for sure.
Oh, since the issue seems limited to a hot engine, be sure to check for leaks after the engine gets up to temp. Maybe ride it for a while beforehand to get the idle speed in the problem range?
SixDD (08-20-2018)
by the time I were to test for intake leaks on the bike when it was warmed up it would have settled back to a normal idle. I was thinking about duct taping the throttle grip to give it partial throttle while checking for intake leaks, after the bike has warmed up. Maybe it only leaks when it is at a higher throttle when there is extra suction going on at the intake seals.
