Custom Street Bob Fender on Fat Bob Write Up
Hey guys so recently I attached a 2012 street bob fender on to my 2009 fat bob. I took lots of pictures and figured I'd post a quick guide on what I did and how I did it since the normal route is to go wide glide.
I chose a street bob fender because I like the narrowness of it and don't mind the small gap between the struts and frame.
First things first, remove the seat to expose the wire harness under the seat. note: you don't need to remove the battery or anything of that matter.
Unplug the rear tail-light connector
Using a floor jack or equivalent, place the jack under the rear swing arm and raise the bike to take tension off the shocks.
Now that the bike is lifted, remove the screws on the inner side of the fender to release the turn signals.
Remove both shocks on either side of the bike. Then remove the 2 screws on both sides of the bikes to remove the struts. The fender will come right off at this point.
Next comes to making a custom tail light. I used a 12 LED light bar (generic) off ebay for around $27. Using a DMM, I ohmed out original harley connector to find out which wires correspond to brakes, signals etc. The top left is the left signal, fat right wire is the right signal. The purple is ground and other 2 are running or license plate, either will work. I add wire to the light bar and connector to about 3 feet, measure 2x and cut once depending on how you go. I sleeved the cable with snakes skin to shield it form the environment.
To attach the new cable, I used the cheap 3M adhesive zip ties brackets along with zip ties to route it up the middle of the fender. I attached the LED tail/brake/signal light bar using 3M 25lb double sided tape and simple metal tabs found in the door department of home depot. Apply and trim up with an exacto knife and position at the center of the fender.
To re-attach the fender, simply use the old struts and mounting hardware. On my bike I had quick attach brackets for a back rest. To make the front bolts reach the struts/fender I got 2" 3/8 bolts form Lowes. Re-attach until the struts apply lots of tension and apply blue Locktite.
Presto!
Presto!
The tape marks left on the inside of that fender look like my old fender (did I sell you that fender?) The fender looks good on your ride, only change I would have made is running the wire along the corner radius of the fender where there is zero possiblity of contact with the tire.
grebskiFXDF...glad it worked out for you, man. It does look good!
