USB power wire - dumb question
Sounds about right, however I would think (not an offical answer) that little red flashing light on the dash or the on-board clock/memory would end up causing more battery drain then this connector if the bike were to sit for extended amounts of time.
Actually it will be an electronic regulator (solid state chip) but the quiescent current (no load) should be under 0.001 Amp, less than the self-discharge rate of the battery.
Its always worth fitting it into a switched circuit, as stated above, it is a solid state regulator which is powered all the time if directly connected to the battery. The issue is that if It develops a fault it can self destruct as has been known with cigar lighter versions in cars as they use the same circuitry.
1: That device lowers the voltage from 12 volts (motorcycle battery) to 5 volts at all times that it is connected.It is a small amount of power consumed but it is a slight drain.
Some folks have a windshield bag and have used similar cable/usb by obtaining power from headlight. It will power only when headlight is on, device contains a low rated fuseable link and is very close to handle bars so there is very little cable to run.
2: If the bike has a battery tender plug and this is for limited use then maybe something like this might be easier and quicker http://www.batterytender.com/Accesso...arger-QDC.html
