I can't figure out how to remove my battery / 2005 superglide...the owners manual says there is a "rear upper bolt" holding it together / can't locate / very frustrating, I'm trying to install a pig-tail for a battery-tender...HELP !!
Under the battery box there are two bolts. One bolt is horizontal and the other is vertical. Loosen the horizotal bolt all the way out and then the vertical bolt till the battery box is almost lose. If you can take the negative bolt of the battery post do that first and move the cable so it doesn't touch the battery negative post.
