Dyna Rear Pulley Bolts
Yes there is a huge thread on this somewhere, you could use the "Search" feature at the top of the page and find it. I just replaced my rear pulley and went with aftermarket(Diamond Engineering) ones. Definitely have to be careful when replacing those bolts, need to only use new bolts, clean out the hub threads, use Red Loctite 262 if no threadlocker, and torque properly per your HD Service Manual - refer to HD Service Bullitin M-1219 if your SM came out before 2009. Even doing all this right, you need to check them periodically to see if they are losing their torque.
Oh yeah, welcome to the HD Forums!
Thanks for the welcome, the bike was on the lift the night before and the bolts where checked when they where installed red loctite was used, I had to drill out all five broken bolts and they did not come out easy. Just has a note HD states they are grade 8 bolts but I have never drilled through a grade 8 bolt so easy the drill went through them like butter.
Nah...stainless would be a b*&tch to drill out. And contrary to what was said...dont use RED locktite if you have an aluminum hub...you will damage threads. Use blue on alloy wheels.
Guest
Posts: n/a
