Back-off brake light module install on a 99-06
I installed a Signal Dynamics Back-off brake module on my 02' Wide Glide. I took the seats off and the brake wires are routed under the fender and then up and through the frame to the left side of the battery. There is just a little room to splice or solder connections. I cut the tie wire holding several wire looms and found the wire loom going to the brake/turn signals. I spliced the Back-off module wires into the brake light wire (red/yellow), taped it up and zip tied all the wire looms back up. I used the supplied double sided tape to mount the Back-off module inside the left frame on the back of the coil mounting plate. Turned out to be an easy 15 min. job. Hopefully, it will keep tailgaters back a bit further, and alert other drivers at stop lights.
