It doesn't look THAT bad... or, does it?
It's a 7 3/4 inch light
It just now got dark enough for me to test it out. It WORKS about a zillion times better than the dinky little thing Harley put on it! I knew it would. To me, being able to see at night is like, far more important than having a pretty headlight.
So now I have a stock headlight for a 07 Dyna - anyone?
Install was easy - just nipped the stock wiring ('cause the plug would not come out where I could get to it), fed it into the new light, stripped the wires back, put some shrink fit tubing on the wires, soldered then together, moved the shrink fit up around the joint, heated it up and, presto, it shrank tight to the wire.
