Swirl marks in vivid black paint
Old 05-15-2012 | 08:10 PM
2014streetglide's Avatar
2014streetglide
Default Swirl marks in vivid black paint
Hey there. I have some work marks in my vivid black paint. They aren't real bad but I would like to take care of them. Anyone ever use the Harley scratch and swirl remover? Also after I use a scratch or swirl remover do I need to wax after? And would the turtle wax ice wax be a good enough wax after? Thanks for any info
Old 05-15-2012 | 08:12 PM
soft 02's Avatar
soft 02
Meguiers scratch-x. Wax as normal after
Old 05-15-2012 | 08:20 PM
Jeff W's Avatar
Jeff W
Turtle wax black box, three step process but looks good. Truly though only buffing will get rid of scratches of any depth. The little swirls though, black box.
Old 05-16-2012 | 08:11 PM
2014streetglide
Will the black box leave any residue on the rubber gasket of the console? Also can I use it over the decals? They have the clear over them from the factory.
Old 05-17-2012 | 07:48 AM
Sammi's Avatar
Sammi
+1
Had some intense swirls and light scratches.
Great stuff that Scratch X V2. Use a good paste wax afterwards.
Sammi
Old 05-30-2012 | 11:52 PM
D.Stewart's Avatar
D.Stewart
Zaino is by far the best wax I have ever used. Its a very long, time consuming process, but well worth the end result. And well worth the $$$.
Old 06-26-2012 | 06:28 PM
Rattletrap 96's Avatar
Rattletrap 96
Meguiars swirl x yellow foam pad orbital buffer ...repeat till you get the results you want ...just did my tank ..UNREAL RESULTS
Old 06-27-2012 | 05:32 PM
Nocturnalnature's Avatar
Nocturnalnature
I second this.
Lots of people mistake Swirl X and Scratch X, both made by Mequiars. The Swirl X is not as aggressive and does a fine job on the light swirl marks made by wiping the bike down?
Start by wiping the bike down with a 50/50 blend of distiller water and alcohol to strip the wax, use the Swirl X and foam pad until satisfied with the results, follow up with a polish to restore the shine, and finish with a high quality wax. Works like a charm but does take time and tired arms since the cutting agent is so fine. Maintain with a quick detailer spray and use only high quality microfiber towels to avoid future swirls.
Old 07-14-2012 | 07:13 PM
_Gir_'s Avatar
_Gir_
It's not a wax, it's a sealant. Similar in concept but basically you get longer protection. On the other hand you will give up the voluptuous finish carnuba waxes provide.
Old 07-16-2012 | 12:36 AM
R Eggler's Avatar
R Eggler
Any "swirl remover" is just a glaze, great for shining, but doesn't tend to last long. Best to use a sealing wax after. Any use of a buffer will cause swirls, don't care if it's a rotary or random orbital, it'll cause swirls with just how they make the products work.
And Turtle wax "ICE" is by far the worse crap I've ever come across. I don't care if it doesn't leave residue on plastic, it's like putting tire shine on your paint. Sure it looks good, but it's terrible for your paint. I got a bottle for free, I've tried it several times in many different situations and I'm about to give it to some other poor sap.
teedubbyaw
08-11-2016 01:01 PM
Ironcleveland
04-20-2015 12:46 AM
luisan
01-19-2014 01:30 PM
uuscotty
04-02-2013 03:41 PM
Geezr Glidr
09-07-2012 10:32 PM
