BEST WAY TO REMOVE DUST ???
BIKE SITS IN THE GARAGE WITH A DUST COVER ON IT / ALWAYS A FINE COAT OF DUST ON IT WHEN I REMOVE COVER / WHAT IS THE BEST WAY TO "DUST" THE BIKE OFF? IT IS BLACK WITH A GOOD COAT OF WAX ON IT. MATTER OF FACT IT IS BRAND NEW. [8D] THANKS GUYS, BILL
JUST ONE OF MANY MORE DUMB QUESTIONS TO FOLLOW !!!!!!!!!!!!!!!!!
RE: BEST WAY TO REMOVE DUST ???
I used these when I was into the car seen, now I use the smaller version seen here for my bike. Just hit it with an air compressor first, just in case any big particles made it under the cover (unlikely).
Benji
http://www.calcarcover.com/product.a...=1019&cid=
Benji
Hit what with the air compressor? The bike or the cover?
Never ever use the compressor to blow anything off your bike. If you need to quickly clean your paint use a "quailty" waterless wash. Quick and Wash is one the can be found local..Walmart...it can be mixed in a spray bottle.
Its a good idea to wrap duster in newspaper before using. Also do not wash duster.
As I said above..the best way to remove dust is using a waterless wash or a quick detailer. The least expensive and most effective will be Quick and Easy Wash (made by ProtectAll) available at Walmart in boating section or any camper supply. You can add about a 1/4 oz or less to a 16oz spray bottle of water. Spray on Wipe Off.....this is a rinseless formula.
We never recommmend dry dusting.
