Clean Pipes?
11-03-2006, 07:50 PM
Clean Pipes?
How do you clean the rubber or sole marks from your shoes from the pipes?
11-03-2006, 07:53 PM
RE: Clean Pipes?
Spray easy of oven cleaner on a rag an then clean the pipe with that. Careful not to get easy off on anything but the pipes...
11-03-2006, 08:01 PM
RE: Clean Pipes?
Thanks! I just read down further and found another post. Sorry for that.
11-03-2006, 08:18 PM
RE: Clean Pipes?
a razor blade will work too
11-03-2006, 08:50 PM
RE: Clean Pipes?
If you use a razor blade be careful cause it will distroy your pipes. Been there done that. If you get to it early enough then you can use a plastic razor when the ruber is heated up.
Robbysride
Detailing
20
04-04-2015 10:59 AM
SPFRUSCIONE
04-20-2011 07:53 PM
charleskmoore2
Detailing
03-03-2009 11:35 AM
mke125125
01-29-2008 06:36 PM
CharlieBox
01-07-2008 04:21 PM
