Dips and sags in Bags
RE: Dips and sags in Bags
Easy to fix. There are a couple of companies making kits to fix them. The only one I have any experience with is called "Saggy Bags" or something like that. You can do a search here on the forum and find the thread on them. I helped a friend put them on his heritage and it made a huge difference.
Never mind, I found it for you. Check this out: http://www.gotsaggybags.com/
The Saggy Bags will do it for you. If you've got some basic tools you can buy some 1/8" ABS plastic and make a template for the top of the bags and then cut the plastic and glue it in. Same for the side of the bag and a heat gun will bend it over the edge for you. I used some scrap ABS that I picked up for $15 bucks and about one hour later I had my own "Saggy Bags". Just a thought...
