Removing Swirls from Polished Aluminum
I use a number of products to polish out swirls and small scratches on alloy parts. Check this thread and my Post#36. This shows my upper and lower trees next to chrome. My trees were not polished from the factory or clear coated.
https://www.hdforums.com/forum/gener...luminum-2.html
Try any of the larger truckstops in your area. They should have something in the parts and accessories area of the store. Moshers is one that I used to use on my aluminum rims and tanks on my KW that worked well. Make sure you stay away from any that have ammonia in their makeup as it will act as an acid and cause rapid oxidation and surface breakdown in the aluminum later down the road after polishing. Also, put a good couple of coats of wax on after polishing to keep the metal from being exposed to the elements as the polish does not generally include a protective element.
If you try a metal polish, like Mothers Billet Polish or Mag & Aluminum Polish, or most any other true metal polish and the towel turns black, it's not clearcoated and you can keep polishing. You might need a general purpose polish like Mag & Aluminum Polish to remove the scratches, then follow with Billet Polish for a mirror shine. Working small areas at a time, polish lightly with a soft microfiber to create a buttery black residue and wipe with a very soft microfiber while still wet.
If they are clearcoated, try any paint polish, polishing compound, or even plastic polish if you have it. If push comes to shove, try a scratch remover or polishing compound.
A Mothers PowerCone working at low speed can really save some time on this project with any polish.
