brake issue. helo please
Old 08-08-2013 | 01:02 PM
rod197's Avatar
rod197
Default brake issue. helo please
Hey have an 93 flh being restored and customized. Builder converted front and rear to 2002 axles and rear swing arm. On rear he can't get brakes to work so far. Said master needed rebuilt. My Concern is weather the rear master of an 93 has enough bore to run the dual piston caliper on the 2002 swing arm. Builder said that the conversion was no big deal. Has anyone else done this and how did it work.
Old 08-08-2013 | 11:26 PM
misfitJason's Avatar
misfitJason
Use the master for that brake. Make sure you are running the right fluid too. Dot 5 doesn't work for dot 4
Old 09-09-2013 | 10:57 PM
TwiZted Biker's Avatar
TwiZted Biker
It'll work most rear MC's are 3/4" bore and I run 2 4piston calipers on mine with no problems , it's the front MC's that get into the size issue .
KozmoSoftail98
EVO
10-26-2017 04:59 PM
1st 96 ultra
05-24-2015 07:46 PM
aharley1
07-01-2008 08:03 PM
Old Texas Gringo
03-10-2008 03:46 PM
Timboto
Shovelhead
09-18-2007 11:42 AM
