Raked trees
Raked trees are absolutely necessary on bikes that have more rake in the frame neck than stock. For example, on a frame with 40 degrees on frame neck, you would definitely need 5 or 6 degree trees.
Using raked trees on a stock frame (30 degrees) is generally not a good idea...but 3 degree trees seems to be ok. Factory wide glide trees have 3 degrees built into the trees.
67 LS1
09-26-2006 08:51 PM
