72 paughco frame
72 paughco frame
hi, i found a 72 paughco for sale. it is a basic sportster frame right? i did a google search, and i found some with jap engines. is it just a build it the way you want thing? i emailed the guy, but haven't been able to talk to him. the ad says it runs but the oil lines leak. is this a real bad thing? what else do i look at to see if its a rip off? thanks
Are You for real? If you want some help post some pics! Without them all I can tell You is Paughco has made frames for many years and for many - many - many different applications.These are aftermarket frames either replacement or custom frames. Find out what you are buying.Is it a Sporty drive line or something else. Ask the seller how it is tittled and what year the engine,trans,frt end is.
Don.t be afraid to ask,if there is nothing to hide the seller will answer you! Good Luck !
