You can build your own custom.
It was time for wires. Look at that photo. It is scary isn’t it?
Actually, wiring is not that hard. It is time consuming and you have to double check yourself constantly. I purchased this little unit from Thunder Heart and all of the wires for the bike go through it. It requires only that you mount a 30 Amp fuse or circuit breaker between it and the battery.
In addition, there was a Thunder Heart ignition control module which I mounted under the tank. Sorry. No photo was taken of that. That module works in conjunction with the Thunder Heart coil and the ignition system is programmable with a lap top computer. This is definitely a first class system and my hat is off to the folks at Thunder Heart. Check out their web site at http://www.thunder-heart.com/Home.html.
Here are some photos of the finished product. Some details I did not go into are the Küryakyn signal light/mirror assemblies, the Küryakyn bullet tail lights, the custom license plate bracket/ tail light assembly, the Jay Brake forward controls, the Joker Machine hydraulic clutch, the chrome hand controls, the PM brakes, etc. etc. etc.
I sent the rear fender braces, the shifter arm and the rear wheel adjusters to Chromemasters in Nashville, TN. for chroming. They did a nice job. Look them up at http://www.chromemasters.com/.
I received the frame on July 6, 2007 and I started the bike for the first time on February 24, 2010. As I said, I was not in a hurry and I was able to pay for everything as I went along. The handling of this machine has exceeded my expectations so my hat is off to Paughco. If you read this entire thread, my hat is off to you too.
You certainly can,my last four bikes have all been ground up built saving huge coin.Last two are are hot rod Road Kings one powered by S&S 124" Evo $16k, the other R&R 155" TwinCam tad over $22k.Bought most of the major chassis parts off Ebay,built the bikes over winter took about 6 months each.
You did a GREAT job on this project!!
I'm not a professional mechanic (just weekend wrencher), or a machinist, or engineer, or anything even remotely related to these.....just an average guy interested in trying to build a bike from scratch. I did a similar project a couple of years ago - starting with a bare frame, working sporadically for ~2yrs nights & weekends, and ending-up with a full-blown custom. While there are things I'd do differently, I'm pretty pleased with my first attempt at something like this....and I learned a hell-of-a-lot along the way!! Specs:
127" show-polished R&R motor
3" Primo open belt primary
6-spd Baker RSD tranny
Pro-One frame (originally softail, but now rigid with struts replacing the shocks)
300mm rear tire
Custom paint (the ONLY part of this project I didn't do myself....I'm not that talented)
300mm rear tire
300mm rear tire
300mm rear tire
You always learn from these projects, I don't care how much experience you have. From the looks of the photo, you did a superb job on yours so congratulations to you too.
