Help, I got oil coming out of breather?
I have a 96" Ultima motor in My custom bike. I went out to start the bike. It would not crank over. The starter was not clicking, it just would not turn over so I hooked up a nother battery to it and it finally cranked over. It started up and seemed to be running fine. I turned around to put some air in the front tire and when I turned back towards the bike there was oil all over. Probably at least a cup or 2, so I immedieately shut the bike off. I pulled the air cleaner off to get a better look and could not tell where it was coming from, so I started it up again. After about 10-15 seconds the oil started running out the breather line. By the time I shut it off, there was a quart or better of oil on the bike and the ground.
are you also running the lower breathers? ive got a 127" ultima and i run both head and case breathers.your problem is that your lower end is full of oil,check the ball in the oil pump for debris,take the drain plug out of the bottom of the cases and drain,put about 1/8 of a quart back in thru the timing hole,and fire up,you should be fine
kirby
kirby
skymurphy991
Oil Archive (no new posts)
02-06-2013 09:08 PM
