got another ride yesterday
#282
ha ha ha we will see i am going to drop it down first... if anyhting i will polish them out and then clear them... first i want to ride it!
bike looks completely diff on the ground next to how it sits on a lift...i am going to take it down tomorrow for a frew pics
ok... well i set up shop outside cause it was 50 degrees... i got the seat sanded down and primed.... still needs to be sanded again and glazed, primed and painted but it was a great start! also finished both sides of the linkage... just need to powder the brake side
(sorry about the crap pics all i have is my cell, girl has the camera in TN this weekend)
shifter side
brake side (needs pow wow)
shifter side
#284
just a small sheet of foam... thats all... either that or i may make something to hold it that is diff but just a bit of foam, it is not supposed to be comfortable... it is a cafe, this bike is going to rip RIP turns... i got heavy weight oil in the forks (complete rebuild with seals) fork brace, 2 brand new Cheng Shin Tires, new bearings, new pads in front on complete rebuilt caliper and master cylinder with dot 5 fluid, new rear drum pads, and sport performance rear shocks.... this little sucker is going to RIP in the turns! air scoop and oil cooler to keep that motor cool as i am rocking in high RPM's ooh ya buddy! i can not wait!
#285
#286
#288
tonight i got my one of my MAIN worrys out of the way! I got the oil cooler and adapter all finished up! I shaved the side case even more to allow me to remove that without having to undo the oil lines... i used a bit of permatex on the adapter to help give me a good solid seal... came out GREAT! i was running out of stuff to do so i shaved the side cover so the oil lines can get though and then cut out the holes where the screens i am making in the near future will go. Even tossed on the red lenses for the tail/ brake lights (that will stay white)
case shaved out
all done and the linkage back on
tails:
case shaved out
tails:
#289
ok... I NEED BODY WORK HELP!
man! for the life of me i can not get this sucker STRAIT and true... i have all these creators in the seat... i primerd it to see them a bit better... any tips or just sand sand sand! i dont want my set to look like a 14 year old kids face.... i want it SMOOOOOOOTH... should i be bondo'n more.... should i be glazing it? i am lost
here is what i mean:
#290
