Wiring Question re: ignition switch
I have a three position barrel type starter switch. I am wiring my custom and need to know what the three posts are on the back side of the switch. They are labelled B, IG and L. I assume IG is ignition and L is lights. Not sure what B stands for.
When I hook up, what wires go to the terminals on the switch? My wiring harness I am using has two leads to the ignition switch. One RED and one RED/BLACK. Not sure which one goes where and what wire connects to the third terminal on the switch itself. Starter wire? console wire?
RGM
RGM
RE: Wiring Question re: ignition switch
Here is a diagram I've used. The "ACC" position will be the same as your "L" If your running an electronic ignition, some of this wiring will not apply to your build, actually it'll be a bit simpler. I don't know how complicated you plan on getting with turn signals and such, but this is a good basic diagram. Helps to understand the flow of things...
Blk80bike
Electrical/Lighting/Alarm
09-25-2016 08:09 AM
rgm
11-22-2007 10:00 PM
